Dynamic of tubes crossed by high speed projectiles : influence of tube and weapon geometry on accuracy and dispersion
Dynamique des tubes parcourus à grande vitesse : influence de la géométrie des tubes et leur environnement sur la justesse et la dispersion
Gun accuracy is influenced by several factors during the stages of the ammunition course (internal, intermediate and external ballistics). According to previous studies, internal ballistics are the major contributor to deviations from target. Indeed, this phase determines projectile exit conditions and, consequently, his behavior during the flight. The projectile entry conditions, the weapon and barrel geometry and their movements during firing, can modify the interaction tube / projectile and change ammunition angular rates and its transversal velocities. The purpose of this thesis is to determine the parameters related to barrel and gun geometry, which influence the bias and the dispersion. A statistical analysis was led thanks to the data base of the 25 mm firing results. It was found that some parameters, including barrel straightness, affect accuracy. Subsequently, tests were conducted with a firing appliance in order to isolate the barrel geometry influence on the deviations from the target and to confirm the straightness impact. A tridimensional numerical model was created in order to vary this parameter and to study its influence on the ammunition behavior during internal ballistics. The representativeness of the model was validated using accelerometers embedded in the ammunitions. The firing of these ammunitions has required the development of an optoelectronic system to transmit accelerations in real time. The comparison between experimental and numerical results has shown close amplitudes and similar shapes curves that proves the representativeness of the model. The model can be used now to lead parametric analysis and to determine the straightness shapes the most penalizing for gun accuracy.
La précision de tir d’une arme dépend de nombreux facteurs intervenant aux différentes étapes du parcours de la munition (balistique intérieure, intermédiaire et extérieure). Certains travaux ont démontré l’importance de l’influence de la phase de balistique intérieure, pendant laquelle la munition traverse le tube, sur les résultats à la cible. En effet, c’est cette phase qui détermine les conditions de sortie du tube de la munition et par conséquent son comportement au cours du vol. Les conditions d’entrée du projectile, la géométrie du tube et de l’arme, et les mouvements de ces derniers au cours du tir, sont autant de paramètres pouvant modifier l’interaction tube/projectile et ainsi entraîner un changement des vitesses angulaires et de translation de la munition au moment du largage. Cette étude a donc pour but de mettre en exergue les paramètres géométriques de l’arme et du tube qui influencent la justesse et la dispersion. Une analyse statistique a été réalisée à partir de la base de données des résultats de tir du 25 mm. Elle a permis de mettre en évidence l’influence de plusieurs paramètres dont la rectitude du tube. Par la suite, des essais ont été conduits en appareil de tir dans le but d’isoler la part de la géométrie du tube sur les écarts à la cible et ainsi de confirmer la contribution de la rectitude. Un modèle numérique tridimensionnel a été développé afin de faire varier ce paramètre et d’étudier son influence sur le comportement de la munition en phase de balistique intérieure. La représentativité du modèle a été vérifiée à l’aide d’accéléromètres embarqués dans la munition. Ces tirs ont nécessité le développement d’une solution innovante optoélectronique afin de transmettre les accélérations en temps réel. Les résultats expérimentaux obtenus ont permis de constater que les accélérations de la munition modélisée étaient représentatives. Le modèle permet maintenant de réaliser des études paramétriques et de déterminer les profils de tube les plus pénalisants pour la précision de tir.
