Evaluating potential for ground and surface water contamination from new and traditional munitions
Évaluer le potentiel de contamination des eaux souterraines et de surface par les munitions nouvelles et traditionnelles
Contamination of training grounds due to energetic compounds is a persistent problem both in France and in the United States. With the development of new insensitive munitions, a new set of compounds is being introduced to the environment. The new compounds are more soluble and therefore can have greater mobility in the environment and higher potential for contaminating ground and surface waters. This study is evaluating fate and transport of traditional explosive compound 1,3,5-hexahydro-1,3,5-trinitro-1,3,5-triazine (RDX) and new ones: 3-nitro-1,2,4-triazol-5-one (NTO) and 2,4-dinitroanisole (DNAN) in two environments with contrasting climatic conditions, in Camp Militaire de Bitche, in Moselle region of France, location of OHM Bitche County observatory, with wet conditions and organic soils, and in Fort Huachuca, AZ, an arid environment, in close vicinity of the Human-Environment Observatory (OHM) Pima County. Soils have been collected at both locations at or in proximity of military installations. We are conducting adsorption and transformation experiments to determine fate and transport parameters for the surface soils for both locations as well as subsoils, which are rarely examined and parameters for which are assumed. We are performing transformation experiments for both aerobic and anaerobic conditions to reflect the effect of prolonged water saturation on fate of studied compounds. Role of microorganisms in the transformation will be examined. Once parameters have been determined we will conduct modeling for both locations and several climate scenarios (current climate and projected changes in the future) to predict potential contamination.
La contamination des terrains d'entraînement par des composés énergétiques est un problème persistant tant en France qu'aux États-Unis. Avec le développement de nouvelles munitions à risques atténués, un nouvel ensemble de composés est introduit dans l'environnement. Les nouveaux composés sont plus solubles et peuvent donc avoir une plus grande mobilité dans l'environnement et un potentiel plus élevé de contamination des eaux souterraines et de surface. Cette étude évalue le devenir et le transport du composé explosif traditionnel 1,3,5-hexahydro-1,3,5-trinitro-1,3,5-triazine (RDX) et des nouveaux : 3-nitro-1,2,4 -triazol-5-one (NTO) et 2,4-dinitroanisole (DNAN) dans deux environnements aux conditions climatiques contrastées, au Camp Militaire de Bitche, en Moselle (France), emplacement de l’OHM Pays de Bitche, avec des conditions humides et des sols organiques, et à Fort Huachuca, en Arizona, un environnement aride, à proximité immédiate de l’OHM Pima County. Des échantillons de sol ont été prélevés dans les deux endroits, sur ou à proximité d'installations militaires. Nous réalisons des expériences d'adsorption et de transformation afin de déterminer les paramètres de devenir et de transport des sols en surface pour les deux sites, ainsi que pour les sous-sols, qui sont rarement examinés et dont les paramètres sont supposés. Nous effectuons des expériences de transformation dans des conditions d’aérobies et anaérobies, afin de refléter l'effet d'une saturation prolongée en eau sur le devenir des composés étudiés. Le rôle des micro-organismes dans la transformation sera examiné. Une fois les paramètres déterminés, nous effectuerons une modélisation pour les deux emplacements, en tenant compte de plusieurs scénarios climatiques (climat actuel et changements prévus dans le futur) afin de prédire la contamination potentielle.
PosterPimaCounty_Pays de Bitche_Dontsova_2023.pdf (6.38 Mo)
Télécharger le fichier
