Enriched PUFA environment of Leishmania infantum promastigotes promotes the accumulation of lipid mediators and favors parasite infectivity towards J774 murine macrophages - Institut Pasteur de Tunis Accéder directement au contenu
Article Dans Une Revue Lipids Année : 2022
Abstract Leishmania parasites are the causative agents of visceral or cutaneous leishmaniasis in humans and of canine leishmaniosis. The macrophage is the predilected host cell of Leishmania in which the promastigote stage is transformed into amastigote. We previously showed changes in the fatty acid composition (FA) of lipids in two strains of Leishmania donovani upon differentiation of promastigote to amastigote, including increased proportions of arachidonic acid (AA) and to a less extent of docosahexaenoic acid (DHA). Here, we carried out supplementation with AA or DHA on two Leishmania infantum strains, a visceral (MON‐1) and a cutaneous (MON‐24), to evaluate the role of these FA in parasite/macrophage interactions. The proportions of AA or DHA in total lipids were significantly increased in promastigotes cultured in AA‐ or DHA‐supplemented media compared to controls. The content of FA‐derived oxygenated metabolites was enhanced in supplemented strains, generating especially epoxyeicosatrienoic acids (11,12‐ and 14,15‐EET) and hydroxyeicosatetraenoic acids (5‐ and 8‐ HETE) from AA, and hydroxydocosahexaenoic acids (14‐ and 17‐HDoHE) from DHA. For both MON‐1 and MON‐24, AA‐supplemented promastigotes showed higher infectivity towards J774 macrophages as evidenced by higher intracellular amastigote numbers. Higher infectivity was observed after DHA supplementation for MON‐24 but not MON‐1 strain. ROS production by macrophages increased upon parasite infection, but only minor change was observed between control and supplemented parasites. We propose that under high AA or DHA environment that is associated with AA or DHA enrichment of promastigote lipids, FA derivatives can accumulate in the parasite, thereby modulating parasite infectivity towards host macrophages.
26-Leroux et al Lipids 2022.pdf (1.48 Mo) Télécharger le fichier
hal-04504136 , version 1 (14-03-2024)
Marine Leroux, Hana Bouazizi-Ben Messaoud, Céline Luquain-Costaz, Lars Jordheim, Pauline Le Faouder, et al.. Enriched PUFA environment of Leishmania infantum promastigotes promotes the accumulation of lipid mediators and favors parasite infectivity towards J774 murine macrophages. Lipids, 2022, 58 (2), pp.81-92. ⟨10.1002/lipd.12365⟩. ⟨hal-04504136⟩
12 Consultations
2 Téléchargements
