Second Order and High Order Approaches for Nonconvex Optimization with Objective Function-Free Algorithms - Thèses de Toulouse INP Access content directly
Theses Year : 2024
Approches du second ordre de d'ordre élevées pour l'optimisation nonconvex avec variantes sans évaluation de la fonction objective
Even though nonlinear optimization seems (a priori) to be a mature field, new minimization schemes are proposed or rediscovered for modern large-scale problems. As an example and in retrospect of the last decade, we have seen a surge of first-order methods with different analysis, despite the fact that well-known theoretical limitations of the previous methods have been thoroughly discussed.This thesis explores two main lines of research in the field of nonconvex optimization with a narrow focus on second and higher order methods.In the first series, we focus on algorithms that do not compute function values and operate without knowledge of any parameters, as the most popular currently used first-order methods fall into the latter category. We start by redefining the well-known Adagrad algorithm in a trust-region framework and use the latter paradigm to study two first-order deterministic OFFO (Objective-Free Function Optimization) classes. To enable faster exact OFFO algorithms, we then propose a pth-order deterministic adaptive regularization method that avoids the computation of function values. This approach recovers the well-known convergence rate of the standard framework when searching for stationary points, while using significantly less information.In the second set of papers, we analyze adaptive algorithms in the more classical framework where function values are used to adapt parameters. We extend adaptive regularization methods to a specific class of Banach spaces by developing a Hölder gradient descent algorithm. In addition, we investigate a second-order algorithm that alternates between negative curvature and Newton steps with a near-optimal convergence rate. To handle large problems, we propose subspace versions of the algorithm that show promising numerical performance.Overall, this research covers a wide range of optimization techniques and provides valuable insights and contributions to both parameter-free and adaptive optimization algorithms for nonconvex functions. It also opens the door for subsequent theoretical developments and the introduction of faster numerical algorithms.
Même si l'optimisation non linéaire semble (a priori) être un domaine mature, de nouveaux schémas de minimisation sont proposés ou redécouverts pour les problèmes modernes à grande échelle. A titre d'exemple et en rétrospective de la dernière décennie, nous avons vu une vague de méthodes du premier ordre avec différentes analyses, malgré le fait que les limitations théoriques bien connues de ces méthodes ont été discutées en profondeur auparavant. Cette thèse explore deux lignes principales de recherche dans le domaine de l'optimisation non-convexe avec un accent particulier sur les méthodes de second ordre et d'ordre supérieur. Dans la première série de travaux, nous nous concentrons sur les algorithmes qui ne calculent pas les valeurs des fonctions et opèrent sans connaissance d'aucun paramètre, car les méthodes du premier ordre les plus adaptées pour les problèmes modernes appartiennent à cette dernière catégorie. Nous commençons par redéfinir l'algorithme bien connu d'Adagrad dans un cadre de région de confiance et utilisons ce dernier paradigme pour étudier deux classes d'algorithmes OFFO (Objective-Free Function Optimization) déterministes du premier ordre. Pour permettre des algorithmes OFFO exacts plus rapides, nous proposons ensuite une méthode de régularisation adaptative déterministe d'ordre p qui évite le calcul des valeurs de la fonction. Cette approche permet de retrouver la vitesse de convergence bien connu du cadre standard lors de la recherche de points stationnaires, tout en utilisant beaucoup moins d'informations. Dans une deuxième série de travaux, nous analysons les algorithmes adaptatifs dans le cadre plus classique où les valeurs des fonctions sont utilisées pour adapter les paramètres. Nous étendons les méthodes de régularisation adaptatives à une classe spécifique d'espaces de Banach en développant un algorithme de descente du gradient de Hölder. En plus, nous étudions un algorithme de second ordre qui alterne entre la courbure négative et les étapes de Newton avec une vitesse de convergence quasi optimal. Pour traiter les problèmes de grande taille, nous proposons des versions sous-espace de l'algorithme qui montrent des performances numériques prometteuses. Dans l'ensemble, cette recherche couvre un large éventail de techniques d'optimisation et fournit des informations et des contributions précieuses aux algorithmes d'optimisation adaptatifs et sans paramètres pour les fonctions non convexes. Elle ouvre également la voie à des développements théoriques ultérieurs et à l'introduction d'algorithmes numériques plus rapides.
JERAD_Sadok.pdf (2.13 Mo) Télécharger le fichier
Origin : Version validated by the jury (STAR)
Dates and versions
tel-04539100 , version 1 (09-04-2024)
Identifiers
  • HAL Id : tel-04539100 , version 1
Cite
Sadok Jerad. Second Order and High Order Approaches for Nonconvex Optimization with Objective Function-Free Algorithms. General Mathematics [math.GM]. Université de Toulouse, 2024. English. ⟨NNT : 2024TLSEP024⟩. ⟨tel-04539100⟩
47 View
12 Download
Share
