On the controllability of the quantum dynamics of closed and open systems - Centre de mathématiques appliquées (CMAP) Accéder directement au contenu
Thèse Année : 2018
Sur la contrôlabilité de la dynamique quantique des systèmes fermés et ouverts
We investigate the controllability of quantum systems in two differentsettings: the standard 'closed' setting, in which a quantum system is seen as isolated, the control problem is formulated on the Schroedinger equation; the open setting that describes a quantum system in interaction with a larger one, of which just qualitative parameters are known, by means of the Lindblad equation on states.In the context of closed systems we focus our attention to an interesting class ofmodels, namely the spin-boson models. The latter describe the interaction between a 2-level quantum system and finitely many distinguished modes of a bosonic field. We discuss two prototypical examples, the Rabi model and the Jaynes-Cummings model, which despite their age are still very popular in several fields of quantum physics. Notably, in the context of cavity Quantum Electro Dynamics (C-QED) they provide an approximate yet accurate description of the dynamics of a 2-level atom in a resonant microwave cavity, as in recent experiments of S. Haroche. We investigate the controllability properties of these models, analyzing two different types of control operators acting on the bosonic part, corresponding -in the application to cavity QED- to an external electric and magnetic field, respectively. We review some recent results and prove the approximate controllability of the Jaynes-Cummings model with these controls. This result is based on a spectral analysis exploiting the non-resonances of the spectrum. As far as the relation between the Rabi andthe Jaynes-Cummings Hamiltonians concerns, we treat the so called rotating waveapproximation in a rigorous framework. We formulate the problem as an adiabaticlimit in which the detuning frequency and the interaction strength parameter goes to zero, known as the weak-coupling regime. We prove that, under certain hypothesis on the ratio between the detuning and the coupling, the Jaynes-Cumming and the Rabi dynamics exhibit the same behaviour, more precisely the evolution operators they generate are close in norm.In the framework of open quantum systems we investigate the controllability ofthe Lindblad equation. We consider a control acting adiabatically on the internal part of the system, which we see as a degree of freedom that can be used to contrast the action of the environment. The adiabatic action of the control is chosen to produce a robust transition. We prove, in the prototype case of a two-level system, that the system approach a set of equilibrium points determined by the environment, i.e. the parameters that specify the Lindblad operator. On that set the system can be adiabatically steered choosing a suitable control. The analysis is based on the application of geometrical singular perturbation methods.
On etudie la contrôlabilité des systèmes quantiques dans deux contextes différents: le cadre standard fermé, dans lequel un système quantique est considéré comme isolé et le problème de contrôle est formulé sur l'équation de Schrödinger; le cadre ouvert qui décrit un système quantique en interaction avec un plus grand, dont seuls les paramètres qualitatifs sont connus, au moyen de l'équation de Lindblad sur les états.Dans le contexte des systèmes fermés on se focalise sur la classe intéressante des systèmes spin-boson, qui décrivent l'interaction entre un système quantique à deux niveaux et un nombre fini de modes distingués d'un champ bosonique. On considère deux exemples prototypiques, le modèle de Rabi et le modèle de Jaynes-Cummings qui sont encore très populaires dans plusieurs domaines de la physique quantique. Notamment, dans le contexte de la Cavity Quantum Electro Dynamics (C-QED), ils fournissent une description précise de la dynamique d'un atome à deux niveaux dans une cavité micro-onde en résonance, comme dans les expériences récentes de S. Haroche. Nous étudions les propriétés de contrôlabilité de ces modèles avec deux types différents d'opérateurs de contrôle agissant sur la partie bosonique, correspondant respectivement – dans l'application à la C-QED – à un champ électrique et magnétique externe. On passe en revue quelques résultats récents et prouvons la contrôlabilité approximative du modèle de Jaynes-Cummings avec ces contrôles. Ce résultat est basé sur une analyse spectrale exploitant les non-résonances du spectre. En ce qui concerne la relation entre l'Hamiltonien de Rabi et Jaynes-Cummings nous traitons dans un cadre rigoureux l'approximation appelée d'onde tournante. On formule le problème comme une limite adiabatique dans lequel la fréquence de detuning et le paramètre de force d'interaction tombent à zero, ce cas est connu sous le nom de régime de weak-coupling. On prouve que, sous certaines hypothèses sur le rapport entre le detuning et le couplage, la dynamique de Jaynes-Cumming et Rabi montrent le même comportement, plus précisément les opérateurs d'évolution qu'ils génèrent sont proches à la norme.Dans le cadre des systèmes quantiques ouverts nous étudions la contrôlabilité de l'équation de Lindblad. Nous considérons un contrôle agissant adiabatiquement sur la partie interne du système, que nous voyons comme un degré de liberté qui peut être utilisé pour contraster l'action de l'environnement. L'action adiabatique du contrôle est choisie pour produire une transition robuste. On prouve, dans le cas prototype d'un système à deux niveaux, que le système approche un ensemble de points d'équilibre déterminés par l'environnement, plus précisément les paramètres qui spécifient l'opérateur de Lindblad. Sur cet ensemble, le système peut être piloté adiabatiquement en choisissant un contrôle approprié. L'analyse est fondée sur l'application de méthodes de perturbation géométrique singulière.
82038_PINNA_2018_archivage.pdf (5.45 Mo) Télécharger le fichier
tel-01760362 , version 1 (06-04-2018)
  • HAL Id : tel-01760362 , version 1
Lorenzo Pinna. On the controllability of the quantum dynamics of closed and open systems. Quantum Physics [quant-ph]. Université Paris Saclay (COmUE); Università degli studi La Sapienza (Rome), 2018. English. ⟨NNT : 2018SACLX017⟩. ⟨tel-01760362⟩
265 Consultations
232 Téléchargements
