Quantum optimal transport is cheaper - Département de mathématiques Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
We compare bipartite (Euclidean) matching problems in classical and quantum mechanics. The quantum case is treated in terms of a quantum version of the Wasserstein distance introduced in [F. Golse, C. Mouhot, T. Paul, Commun. Math. Phys. 343 (2016), 165-205]. We show that the optimal quantum cost can be cheaper than the classical one. We treat in detail the case of two particles: the equal mass case leads to equal quantum and classical costs. Moreover, we show examples with different masses for which the quantum cost is strictly cheaper than the classical cost.
quantbipartiteFGTP2.pdf (365.58 Ko) Télécharger le fichier
hal-02214344 , version 1 (31-07-2019)
hal-02214344 , version 2 (08-08-2019)
hal-02214344 , version 3 (04-05-2020)
Emanuele Caglioti, François Golse, Thierry Paul. Quantum optimal transport is cheaper. 2019. ⟨hal-02214344v2⟩
286 Consultations
361 Téléchargements
