Computation of classical and $v$-adic $L$-series of $t$-motives - Département de mathématiques Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2024
We design an algorithm for computing the $L$-series associated to an Anderson $t$-motives, exhibiting quasilinear complexity with respect to the target precision. Based on experiments, we conjecture that the order of vanishing at $T=1$ of the $v$-adic $L$-series of a given Anderson $t$-motive with good reduction does not depend on the finite place $v$.
Lseries-tmotives.pdf (319.27 Ko) Télécharger le fichier
hal-04410981 , version 1 (22-01-2024)
Xavier Caruso, Quentin Gazda. Computation of classical and $v$-adic $L$-series of $t$-motives. 2024. ⟨hal-04410981⟩
23 Consultations
8 Téléchargements
