Directed topological complexity - Laboratoire d'informatique de l'X (LIX) Accéder directement au contenu
Article Dans Une Revue Journal of Applied and Computational Topology Année : 2019
It has been observed that the very important motion planning problem of robotics mathematically speaking boils down to the problem of finding a section to the path-space fibration, raising the notion of topological complexity, as introduced by M. Farber. The above notion fits the motion planning problem of robotics when there are no constraints on the actual control that can be applied to the physical apparatus. In many applications, however, a physical apparatus may have constrained controls, leading to constraints on its potential future dynamics. In this paper we adapt the notion of topological complexity to the case of directed topological spaces, which encompass such controlled systems, and also systems which appear in concurrency theory. We study its first properties, make calculations for some interesting classes of spaces, and show applications to a form of directed homotopy equivalence.
article_dirtc.pdf (221.78 Ko) Télécharger le fichier
hal-02434377 , version 1 (10-01-2020)
  • HAL Id : hal-02434377 , version 1
Eric Goubault, Aurélien Sagnier, Michael Färber. Directed topological complexity. Journal of Applied and Computational Topology, 2019. ⟨hal-02434377⟩
247 Consultations
146 Téléchargements
