Properties of Ultra-Thin NbN Films for Membrane-Type THz HEB - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue J Low Temp Phys Année : 2008
Various buffer layers have been investigated in order to improve the crystalline quality of NbN ultra-thin films. The structural properties, the thickness, the surface morphology of 5-10 nm NbN films have been studied by different techniques. Uncertainty on thickness measurements in this range and the relation between NbN film quality and gain bandwidth are discussed in the framework of their use in Hot Electron Bolometers (HEB).
Fichier non déposé
cea-00372235 , version 1 (31-03-2009)
  • HAL Id : cea-00372235 , version 1
Bruno Guillet, Ö. Arthursson, Laurence Méchin, M.-N. Metzner, Marie-Pierre Chauvat, et al.. Properties of Ultra-Thin NbN Films for Membrane-Type THz HEB. J Low Temp Phys, 2008, 151, pp.570-574. ⟨cea-00372235⟩
245 Consultations
0 Téléchargements
