Pody: a Solid-based approach to embody agents in Web-based Multi-Agent-Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we discuss the problem of situatedness for agents perceiving and acting on the Web (namely, "Web agents"). Assuming Web agents are embodied on the World Wide Web, then we must define what a Web agent's body is. We first provide an abstract definition of a Web agent's body in terms of what it should comprise. Then we propose a concrete definition of it relying on Solid, a recent Web technology for Social Linked Data: we implement a Web agent's body as a data pod. Consequently, we coin the term pody to refer to the Web entity that embodies an agent on the Web with Solid. This paper summarises the findings of a working group from the Dagstuhl Seminar 23081: Agents on the Web (February 19-24, 2023).
EMAS_2023_Pody.pdf (271.6 Ko) Télécharger le fichier
emse-04058783 , version 1 (21-08-2023)
  • HAL Id : emse-04058783 , version 1
Antoine Zimmermann, Andrei Ciortea, Catherine Faron, Eoin O'Neill, María Poveda-Villalón. Pody: a Solid-based approach to embody agents in Web-based Multi-Agent-Systems. EMAS 2023 - 11th International Workshop on Engineering Multi-Agent Systems, May 2023, Londres, United Kingdom. ⟨emse-04058783⟩
148 Consultations
45 Téléchargements
