Some issues related to double roundings - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue BIT Numerical Mathematics Année : 2013
Double rounding is a phenomenon that may occur when different floating- point precisions are available on the same system. Although double rounding is, in general, innocuous, it may change the behavior of some useful small floating-point algorithms. We analyze the potential influence of double rounding on the Fast2Sum and 2Sum algorithms, on some summation algorithms, and Veltkamp's splitting.
Version_Finale_DoubleRoundings.pdf (248.35 Ko) Télécharger le fichier
ensl-00644408 , version 1 (24-11-2011)
ensl-00644408 , version 2 (02-12-2011)
ensl-00644408 , version 3 (08-07-2013)
Érik Martin-Dorel, Guillaume Melquiond, Jean-Michel Muller. Some issues related to double roundings. BIT Numerical Mathematics, 2013, 53 (4), pp.897-924. ⟨10.1007/s10543-013-0436-2⟩. ⟨ensl-00644408v3⟩
746 Consultations
397 Téléchargements
