X-Ray Natural Linear Dichroism (XNLD) Applied to the Determination of Relaxations Around Transition Metal Impurities in -Al2O3 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physica Scripta Année : 2005
The local environments around substitutional Cr3+ or Fe3+ ions in doped -Al2O3 have been studied experimentally by dichroic X-ray absorption at the Cr and Fe Kedges in single crystals.A reliable method has been applied to remove diffraction peaks. This paper shows that the dichroic EXAFS analysis leads to the precise determination of the environment around impurity ions in -Al2O3. The Cr or Fe coordination shell in doped -Al2O3 is similar to the one of Cr in -Cr2O3 or of Fe in -Fe2O3. Aluminum or oxygen atoms at a farther distance are weakly affected by the presence of the impurity.
Fichier non déposé
hal-00021945 , version 1 (29-03-2006)
  • HAL Id : hal-00021945 , version 1
Emilie Gaudry, A. Kiratisin, Ph. Sainctavit, Ch. Brouder, Francesco Mauri, et al.. X-Ray Natural Linear Dichroism (XNLD) Applied to the Determination of Relaxations Around Transition Metal Impurities in -Al2O3. Physica Scripta, 2005, 115, pp.1041-1043. ⟨hal-00021945⟩
189 Consultations
0 Téléchargements
