Adaptation Knowledge Discovery from a Case Base - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Fadi Badra
Sandrine Lafrogne
  • Fonction : Auteur
  • PersonId : 836299
Jean Lieber
Amedeo Napoli
Laszlo Szathmary
  • Fonction : Auteur
  • PersonId : 830970
In case-based reasoning, the adaptation step depends in general on domain-dependent knowledge, which motivates studies on adaptation knowledge acquisition (AKA). CABAMAKA is an AKA system based on principles of knowledge discovery from databases. This system explores the variations within the case base to elicit adaptation knowledge. It has been successfully tested in an application of case-based decision support to breast cancer treatment.
definitif.pdf (49.9 Ko) Télécharger le fichier
hal-00110287 , version 1 (27-10-2006)
Mathieu d'Aquin, Fadi Badra, Sandrine Lafrogne, Jean Lieber, Amedeo Napoli, et al.. Adaptation Knowledge Discovery from a Case Base. 2006, pp.795--796. ⟨hal-00110287⟩
154 Consultations
419 Téléchargements
