Multi-armed Bandit, Dynamic Environments and Meta-Bandits - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2006
This paper presents the Adapt-EvE algorithm, extending the UCBT online learning algorithm (Auer et al. 2002) to abruptly changing environments. Adapt-EvE features an adaptive change-point detection test based on Page-Hinkley statistics, and two alternative xtra-exploration procedures respectively based on smooth-restart and Meta-Bandits.
MetaEve.pdf (106.66 Ko) Télécharger le fichier
hal-00113668 , version 1 (14-11-2006)
  • HAL Id : hal-00113668 , version 1
Cédric Hartland, Sylvain Gelly, Nicolas Baskiotis, Olivier Teytaud, Michèle Sebag. Multi-armed Bandit, Dynamic Environments and Meta-Bandits. 2006. ⟨hal-00113668⟩
875 Consultations
1765 Téléchargements
