Proving bounds on real-valued functions with computations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Interval-based methods are commonly used for computing numerical bounds on expressions and proving inequalities on real numbers. Yet they are hardly used in proof assistants, as the large amount of numerical computations they require keeps them out of reach from deductive proof processes. However, evaluating programs inside proofs is an efficient way for reducing the size of proof terms while performing numerous computations. This work shows how programs combining automatic differentiation with floating-point and interval arithmetic can provide some efficient yet guaranteed solvers within the Coq proof system.
article.pdf (151.78 Ko) Télécharger le fichier
hal-00180138 , version 1 (17-10-2007)
Guillaume Melquiond. Proving bounds on real-valued functions with computations. International Joint Conference on Automated Reasoning, IJCAR 2008, Aug 2008, Sydney, Australia. pp.2--17, ⟨10.1007/978-3-540-71070-7_2⟩. ⟨hal-00180138⟩
Collections
INRIA
353 Consultations
195 Téléchargements
