Poleni curves on surfaces of constant curvature - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Rendiconti del Seminario Matematico Année : 2009
In the euclidean plane, a regular curve can be defined through its intrinsic equation which relates its curvature $k$ to the arc length $s$. Elastic plane curves were determined this way. If $k(s)=\frac {2\alpha}{\cosh \left(\alpha s\right)}$, the curve is known under the name ''la courbe des for\c cats'', introduced in 1729 by Giovanni Poleni in relation with the tractrix \cite{Palais1976}. The above equation is yet meaningful on a surface if one interprets $k$ as the geodesic curvature of the curve. In this paper we solve the above equation on a surface of constant curvature.
HanganMureaSari.pdf (352.28 Ko) Télécharger le fichier
hal-00204551 , version 1 (14-01-2008)
  • HAL Id : hal-00204551 , version 1
Théodor Hangan, Cornel Murea, Tewfik Sari. Poleni curves on surfaces of constant curvature. Rendiconti del Seminario Matematico, 2009, 67, pp.59-76. ⟨hal-00204551⟩
257 Consultations
469 Téléchargements
