Extending the Adverbial Coverage of a French WordNet - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
This paper presents a work on extending the adverbial entries of WOLF, a semantic lexical resource for French. This work is based on the exploitation of the derivation and synonymy relations; the latter are extracted from the DicoSyn synonyms database. The resulting semantic resource, which is freely available, is manually evaluated and validated in an exhaustive manner.
BSKFFV09.pdf (104.62 Ko) Télécharger le fichier
hal-00402305 , version 1 (07-07-2009)
  • HAL Id : hal-00402305 , version 1
Benoît Sagot, Karen Fort, Fabienne Venant. Extending the Adverbial Coverage of a French WordNet. NODALIDA 2009 workshop on WordNets and other Lexical Semantic Resources, May 2009, Odense, Denmark. pp.0. ⟨hal-00402305⟩
193 Consultations
138 Téléchargements
