A Combined Semantic and Motion Capture Database for Real-Time Sign Language Synthesis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Over the past decade, many elds of discovery have begun to use motion capture data, leading to an exponential growth in the size of motion databases. Querying, indexing and retrieving motion capture data has thus become a crucial problem for the accessibility and usability of such databases. Our aim is to make this approach feasible for virtual agents signing in French Sign Language, taking into account the semantic information implicitly contained in sign language data.We propose a new methodology for accessing our database, by simultaneously using both a semantic and a captured-motion database, with dierent ways of index- ing the two database parts. This approach is used to eectively retrieve stored motions for the purposes of producing real-time sign language an- imations. The complete process and its in-use eciency are described, from querying motion in the semantic database to computing transitory segments between signs, and producing animations of a realistic virtual character.
IVA2009.pdf (937.8 Ko) Télécharger le fichier
hal-00493426 , version 1 (18-06-2010)
  • HAL Id : hal-00493426 , version 1
Charly Awad, Nicolas Courty, Kyle Duarte, Thibaut Le Naour, Sylvie Gibet. A Combined Semantic and Motion Capture Database for Real-Time Sign Language Synthesis. 9th Int. Conference on Intelligent Virtual Agent (IVA 2009), Sep 2009, Amsterdam, Netherlands. pp.432-438. ⟨hal-00493426⟩
271 Consultations
361 Téléchargements
