Simplicial Differential Calculus, Divided Differences, and Construction of Weil Functors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2011
We define a simplicial differential calculus by generalizing divided differences from the case of curves to the case of general maps, defined on general topological vector spaces, or even on modules over a topological ring K. This calculus has the advantage that the number of evaluation points growths linearly with the degree, and not exponentially as in the classical, ``cubic'' approach. In particular, it is better adapted to the case of positive characteristic, where it permits to define Weil functors corresponding to scalar extension from K to truncated polynomial rings K[X]/(X^{k+1}).
DiffRing.pdf (268.66 Ko) Télécharger le fichier
hal-00516973 , version 1 (13-09-2010)
hal-00516973 , version 2 (11-01-2011)
Wolfgang Bertram. Simplicial Differential Calculus, Divided Differences, and Construction of Weil Functors. 2011. ⟨hal-00516973v2⟩
162 Consultations
153 Téléchargements
