MoDisco: A Generic And Extensible Framework For Model Driven Reverse Engineering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Nowadays, almost all companies, independently of their size and type of activity, are facing the problematic of having to manage, maintain or even replace their legacy systems. Many times, the first problem they need to solve is to really understand what are the functionalities, architecture, data, etc of all these often huge legacy applications. As a consequence, reverse engineering still remains a major challenge for software engineering today. This paper introduces MoDisco, a generic and extensible open source reverse engineering solution. MoDisco intensively uses MDE principles and techniques to improve existing approaches for reverse engineering.
ASE2010-ToolSession-MoDisco.pdf (864.38 Ko) Télécharger le fichier
hal-00534450 , version 1 (09-11-2010)
Hugo Bruneliere, Jordi Cabot, Frédéric Jouault, Frédéric Madiot. MoDisco: A Generic And Extensible Framework For Model Driven Reverse Engineering. 25th IEEE/ACM International Conference on Automated Software Engineering (ASE 2010), Sep 2010, Anvers, Belgium. pp.173-174, ⟨10.1145/1858996.1859032⟩. ⟨hal-00534450⟩
435 Consultations
938 Téléchargements
