Timesheets.js: When SMIL Meets HTML5 and CSS3 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Fabien Cazenave
  • Fonction : Auteur
  • PersonId : 909310
Vincent Quint
  • Fonction : Auteur
  • PersonId : 833612
Cécile Roisin
  • Fonction : Auteur
  • PersonId : 946792
In this paper, we explore different ways to publish multimedia documents on the web. We propose a solution that takes advantage of the new multimedia features of web standards, namely HTML5 and CSS3. To avoid the usual development of complex scripts for handling timing, synchronization and user interaction, we propose to complement HTML5 and CSS3 with SMIL Timesheets. This is made possible by a Timesheets scheduler that runs in the browser. Various applications based on this solution illustrate the paper, ranging from media annotations to web documentaries.
DocEng2011.pdf (456.33 Ko) Télécharger le fichier
hal-00619382 , version 1 (06-09-2011)
  • HAL Id : hal-00619382 , version 1
Fabien Cazenave, Vincent Quint, Cécile Roisin. Timesheets.js: When SMIL Meets HTML5 and CSS3. DocEng 2011, 11th ACM Symposium on Document Engineering, Sep 2011, Mountain View, United States. 10 p. ⟨hal-00619382⟩
824 Consultations
1489 Téléchargements
