New interface
Conference papers
Meat Cutting Tasks Analysis using 3D Instrumented Knife and Motion Capture
Charles Pontonnier 1, 2, * Mark de Zee 1 Afshin Samani 1 Georges Dumont 2 Pascal Madeleine 1
* Corresponding author
2 VR4I - Virtual Reality for Improved Innovative Immersive Interaction
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, ENS Cachan - École normale supérieure - Cachan, Inria Rennes – Bretagne Atlantique
Abstract : This article presents a complete experimental setup and pipeline designed to analyze kinematics and dynamics of meat cutting tasks in terms of musculoskeletal disorder appearance risk. An instrumented knife records the cutting force in 3D. A motion capture system assesses trunk and arm motion in 3D. Finally, the AnyBody software is used to run an inverse dynamics analysis on the recorded motions to obtain muscle forces. At last, EMG records are set up on most of relevant superficial muscles of the shoulder-neck area in order to validate the results. Sample results are proposed for standard workspace parameters, showing the relevance of the information for assessing the risk of developing work-related musculo-skeletal disorders.
Complete list of metadata
https://hal.inria.fr/hal-00640202
Contributor : Charles Pontonnier Connect in order to contact the contributor
Submitted on : Thursday, November 10, 2011 - 10:08:16 PM
Last modification on : Friday, February 4, 2022 - 3:21:53 AM
Links full text
Identifiers
Citation
Charles Pontonnier, Mark de Zee, Afshin Samani, Georges Dumont, Pascal Madeleine. Meat Cutting Tasks Analysis using 3D Instrumented Knife and Motion Capture. 15th Nordic-Baltic Conference on Biomedical Engineering and Medical Physics, Jun 2011, Aalborg, Denmark. pp.144-147, ⟨10.1007/978-3-642-21683-1_36⟩. ⟨hal-00640202⟩
Share
Metrics
Record views
176
