Robust control under weakened real-time constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Patrick Jocelyn Andrianiaina
  • Fonction : Auteur
  • PersonId : 913658
Alexandre Seuret
Daniel Simon
A weakened implementation scheme for real-time feedback controllers is proposed to reduce the conservatism due to traditional worst-cases considerations, while preserving the stability and control performance. Based on recent results to assess stability of linear systems with delayed and sampleddata inputs, this paper takes into account both the effects of deadline misses of control tasks and uncertainties in the plant. The methodology is applied to the pitch control of an aircraft, showing that weakening the real-time constraints allows for saving computing power while preserving the system's stability.
Automatique
CDCECC11_1608_FI.pdf (413.39 Ko) Télécharger le fichier
hal-00640403 , version 1 (11-11-2011)
  • HAL Id : hal-00640403 , version 1
Patrick Jocelyn Andrianiaina, Alexandre Seuret, Daniel Simon. Robust control under weakened real-time constraints. CDC 2011 - ECC 2011 - 50th IEEE Conference on Decision and Control and European Control Conference, Dec 2011, Orlando, Floride, United States. ⟨hal-00640403⟩
300 Consultations
206 Téléchargements
