Impulsive Interference Mitigation in Ad Hoc Networks Based on Alpha-Stable Modeling and Particle Filtering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Nouha Jaoua
  • Fonction : Auteur
  • PersonId : 919812
Emmanuel Duflos
  • Fonction : Auteur
  • PersonId : 844358
Philippe Vanheeghe
  • Fonction : Auteur
  • PersonId : 838038
François Septier
In this paper, we tackle the problem of interference mitigation in ad hoc networks. In such context, the multiple access interference (MAI) is known to be of an impulsive nature. Therefore, the conventional Gaussian assumption can not be considered to model this type of interference. Contrariwise, it can be accurately modeled by stable distributions. Here, this issue is addressed within an Orthogonal Frequency Division Multiplexing (OFDM) transmission link assuming a symmetric -stable model for the signal distortion due to MAI. For this purpose, we propose a method for the joint estimation of the transmitted multicarrier signal and the noise parameters. Based on sequential Monte Carlo (SMC) methods, the proposed scheme allows the online estimation using a Rao-blackwellized particle filter.
ICASSP2011.pdf (79.23 Ko) Télécharger le fichier
hal-00640682 , version 1 (14-11-2011)
Nouha Jaoua, Emmanuel Duflos, Philippe Vanheeghe, Laurent Clavier, François Septier. Impulsive Interference Mitigation in Ad Hoc Networks Based on Alpha-Stable Modeling and Particle Filtering. International Conference on Acoustics, Speech and Signal Processing (ICASSP), 2011, May 2011, Prague, Czech Republic. pp.3548 - 3551, ⟨10.1109/ICASSP.2011.5946244⟩. ⟨hal-00640682⟩
510 Consultations
292 Téléchargements
