Binary Search Method And System For Congestion Avoidance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Brevet Année : 2010
A method for packet flow rate control within a network node (4) receiving at least a traffic flow from a sender (1), comprising the following steps: - computing the average rate at the end of a cycle comprising an initial value of packet number; - updating the value of packet number per cycle in function of the computed average rate with respect to a target flow rate.
Fichier non déposé
hal-00641421 , version 1 (15-11-2011)
  • HAL Id : hal-00641421 , version 1
Alberto Blanc, Sara Alouf, Konstantin Avrachenkov, Georg Post. Binary Search Method And System For Congestion Avoidance. France, Patent n° : EP2413543. 2010. ⟨hal-00641421⟩
Collections
INRIA INRIA2
121 Consultations
0 Téléchargements
