Abstract : This paper proposes a novel algorithm for semisupervised learning. This algorithm learns graph cuts that maximize the margin with respect to the labels induced by the harmonic function solution. We motivate the approach, compare it to existing work, and prove a bound on its generalization error. The quality of our solutions is evaluated on a synthetic problem and three UCI ML repository datasets. In most cases, we outperform manifold regularization of support vector machines, which is a state-of-the-art approach to semi-supervised max-margin learning.
https://hal.inria.fr/hal-00642891
Contributor : Michal Valko <>
Submitted on : Saturday, November 19, 2011 - 3:08:19 PM Last modification on : Tuesday, November 24, 2020 - 2:18:20 PM Long-term archiving on: : Monday, February 20, 2012 - 2:20:52 AM
Branislav Kveton, Michal Valko, Ali Rahimi, Ling Huang. Semi-Supervised Learning with Max-Margin Graph Cuts. International Conference on Artificial Intelligence and Statistics, May 2010, Chia Laguna, Sardinia, Italy. ⟨hal-00642891⟩
