The Rascal Language Workbench - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
Rascal is a programming language for source code analysis and transformation. This means that typically the input of a Rascal program is a program in some programming language, and the output is often yet another program. So Rascal is a meta programming language. Source code is thus primary object of manipulation in Rascal. Many of the use cases that Rascal is designed to address, follow the Extract-Analyze- SYnthesize, or EASY paradigm (shown in Figure 1.1). Meta programs often start by extracting information (facts) from the input program. This is the extraction phase. An example could be the call-graph of a program. Then, this extracted information is often subject to analysis: derived facts are computed, the information is enriched. For the call graph, a simple analysis is determining the root or leaf routines in the a source program by analysing the extracted call-graph. Another analysis could be concerned by identifying routines that are never called (dead code). Finally, the meta program will synthesize some kind of result. This can be transformed source code (e.g., removal of dead code from the input program), a report (e.g., statistics on the number of root and leaf routines), or a visualization (e.g., a graphical depiction of the call-graph). Of course, these phases are not strictly sequential: there may be feedback loops. Some analysis leads to new extraction, synthesis of a result may lead to new analyses and so on. Rascal has elaborated features to support each of the phases of the EASY paradigm fully integrated in the language. Naturally, the implementation of domain specific languages (DSLs), or more generally, modeldriven engineering (MDE) fits the EASY paradigm very well. When implementing a DSL compiler or interpreter the input is, of course, DSL source code. Extraction could, for instance, include the derivation of an AST from the concrete syntax tree. Another extracted model could be a graph-like structure representing the input in a more abstract way, or a performance model. Such abstractions are input to analyses such as constraint checking or type checking, verification, quality-of-service analysis etc. Finally, synthesis covers tasks such as graphical visualization, code generation, and optimization. To conclude, in the context of Rascal, we see DSL implementation as an instance of source code analysis and transformation.
Fichier non déposé
hal-00645985 , version 1 (28-11-2011)
  • HAL Id : hal-00645985 , version 1
Tijs van Der Storm. The Rascal Language Workbench. [Research Report] 2011, pp.1 - 28. ⟨hal-00645985⟩
Collections
INRIA INRIA2 LARA
303 Consultations
0 Téléchargements
