A New Way about using Statistical Analysis of Worst-Case Execution Times
In this paper, we revisit the problem of using Extreme Value Theory (EVT) in the Worst-Case Execution Time (WCET) analysis of the programs running on a single processor. Our proposed statistical WCET analysis method consists of a novel sampling mechanism tackling with some problems that hindered the application of using EVT in the context, and a statistical inference about computation of a WCET estimate of the target program. To be specific, the presented sampling mechanism takes analysis samples from the target program based around end-to-end measurements. Next, the statistical inference using EVT together with other statistical techniques, analyzes such timing traces which contain the execution time data of the program, to compute a WCET estimate with a certain predictable probability of being exceeded.
