Yet Another Meta-Model to specify Non-Functional Properties - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In service-oriented systems non-functional properties become very important to support run-time service discovery and composition. Software engineers should take care of them for guaranteeing the service quality in all the software life-cycle phases, from requirements speci cation to design, to system deployment and execution monitoring. This wide scope and the criticality of non-functional properties demand that they are expressed in a language which is intuitive and easy to use for the service quality specifi cation, and at the same time is machine-processable to be automatically handled at run-time. In this paper we present a Property Meta-Model that aims to reach these two main objectives and show as a proof of concept its use for the modeling of two di fferent properties.
DiMarcoQASBA2011.pdf (703.15 Ko) Télécharger le fichier
hal-00647360 , version 1 (01-12-2011)
  • HAL Id : hal-00647360 , version 1
Antinisca Di Marco, Claudio Pompilio, Antonia Bertolino, Antonello Calabrò, Francesca Lonetti, et al.. Yet Another Meta-Model to specify Non-Functional Properties. International Workshop on Quality Assurance for Service-Based Applications (QASBA 2011), Sep 2011, Lugano, Switzerland. ⟨hal-00647360⟩
Collections
CONNECT
126 Consultations
318 Téléchargements
