Regret Bounds for Gaussian Process Bandit Problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Bandit algorithms are concerned with trading exploration with exploitation where a number of options are available but we can only learn their quality by experimenting with them. We consider the scenario in which the reward distribution for arms is modelled by a Gaussian process and there is no noise in the observed reward. Our main result is to bound the regret experienced by algorithms relative to the a posteriori optimal strategy of playing the best arm throughout based on benign assumptions about the covariance function de ning the Gaussian process. We further complement these upper bounds with corresponding lower bounds for particular covariance functions demonstrating that in general there is at most a logarithmic looseness in our upper bounds.
AISTATS10.pdf (701.79 Ko) Télécharger le fichier
hal-00654517 , version 1 (22-12-2011)
  • HAL Id : hal-00654517 , version 1
Steffen Grünewälder, Jean-Yves Audibert, Manfred Opper, John Shawe-Taylor. Regret Bounds for Gaussian Process Bandit Problems. AISTATS 2010 - Thirteenth International Conference on Artificial Intelligence and Statistics, May 2010, Chia Laguna Resort, Sardinia, Italy. pp.273-280. ⟨hal-00654517⟩
876 Consultations
265 Téléchargements
