Static Scheduling of Latency Insensitive Designs with Lucy-n - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Lucy-n is a data-flow programming language similar to Lustre extended with a buffer operator. It is based on the n-synchronous model which was initially introduced for programming multimedia streaming applications. In this article, we show that Lucy-n is also applicable to model Latency Insensitive Designs (LID). In order to model latency introduced by wires, we add a delay operator. Thanks to this new operator, a LID can be described by a Lucy-n program. Then, the Lucy-n compiler automatically provides static schedules for computation nodes and buffer sizes needed in shell wrappers.
MandelPlateauPouzet-FMCAD-2011.pdf (97.17 Ko) Télécharger le fichier
hal-00654843 , version 1 (23-12-2011)
  • HAL Id : hal-00654843 , version 1
Louis Mandel, Florence Plateau, Marc Pouzet. Static Scheduling of Latency Insensitive Designs with Lucy-n. FMCAD 2011 - Formal Methods in Computer Aided Design, Oct 2011, Austin, TX, United States. ⟨hal-00654843⟩
239 Consultations
206 Téléchargements
