Dynamic QoS Management and Optimisation in Service-Based Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Software Engineering Année : 2011
Service-based systems that are dynamically composed at run time to provide complex, adaptive functionality are currently one of the main development paradigms in software engineering. However, the Quality of Service (QoS) delivered by these systems remains an important concern, and needs to be managed in an equally adaptive and predictable way. To address this need, we introduce a novel, tool-supported framework for the development of adaptive service-based systems called QoSMOS (QoS Management and Optimisation of Service-based systems). QoSMOS can be used to develop service-based systems that achieve their QoS requirements through dynamically adapting to changes in the system state, environment and workload. QoSMOS service-based systems translate high-level QoS requirements specified by their administrators into probabilistic temporal logic formulae, which are then formally and automatically analysed to identify and enforce optimal system configurations. The QoSMOS self-adaptation mechanism can handle reliability- and performance-related QoS requirements, and can be integrated into newly developed solutions or legacy systems. The effectiveness and scalability of the approach are validated using simulations and a set of experiments based on an implementation of an adaptive service-based system for remote medical assistance.
Informatique
tse1.pdf (2.41 Mo) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
hal-00663216 , version 1 (26-01-2012)
  • HAL Id : hal-00663216 , version 1
Radu Calinescu, Lars Grunske, Marta Kwiatkowska, Raffaela Mirandola, Giordano Tamburrelli. Dynamic QoS Management and Optimisation in Service-Based Systems. IEEE Transactions on Software Engineering, 2011, 37 (3), pp.387-409. ⟨hal-00663216⟩
Collections
CONNECT
178 Consultations
935 Téléchargements
