P2P design and implementation of a parallel branch and bound algorithm for grids - Archive ouverte HAL Access content directly
Journal Articles International Journal of Grid and Utility Computing Year : 2009
(1) , (2) , (3, 4)
1
2
3
4
Solving optimally large instances of combinatorial optimisation problems using Branch and Bound (B&B) algorithms is CPU-time intensive and requires a large number of computational resources. To harness such huge amount of resources Peer-to-Peer (P2P) communications must be allowed between resources, and adaptive load balancing and fault-tolerance have to be dealt with when designing and implementing a B&B algorithm. In this paper, we propose a P2P design and implementation of a parallel B&B algorithm on top of the ProActive grid middleware. Load distribution and fault-tolerance strategies are proposed to deal with the dynamic and heterogeneous characteristics of the computational grid. The approach has been promisingly applied to the Flow-Shop scheduling problem and experimented on a computational pool of 1500 CPUs from the GRID'5000 Nation-wide experimental Grid.
Not file
Dates and versions
hal-00690313 , version 1 (23-04-2012)
Identifiers
Cite
Ahcène Bendjoudi, Nouredine Melab, El-Ghazali Talbi. P2P design and implementation of a parallel branch and bound algorithm for grids. International Journal of Grid and Utility Computing, 2009, 1 (2), pp.159-168. ⟨10.1504/IJGUC.2009.022031⟩. ⟨hal-00690313⟩
93 View
0 Download
Share
