New interface
Conference papers
Scaling of the Multilevel Physical Optics parallel algorithm on a large grid
Abstract : The MultiLevel fast Physical Optics (MLPO) algorithm allows to perform Physical Optics integrals with a computational complexity comparable to that of the Fast Fourier Transform (FFT). The multilevel scheme is based on hierarchical domain decomposition and phase compensated interpolation approach. An optimized distributed memory parallelized MLPO algorithm has been designed by partitioning not only the radiating aperture but also the grid of far field directions. The scalability of this algorithm on a large grid is discussed, based on a performance analysis of an MPI-parallelized code.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-00690490
Contributor : Ist Rennes Connect in order to contact the contributor
Submitted on : Monday, April 23, 2012 - 4:39:41 PM
Last modification on : Wednesday, September 30, 2020 - 3:25:24 AM
Identifiers
  • HAL Id : hal-00690490, version 1
Citation
Christian Parrot, Daniel Millot, Christine Letrou, Amir Boag. Scaling of the Multilevel Physical Optics parallel algorithm on a large grid. EUCAP 2010 : Proceedings of the Fourth European Conference on Antennas and Propagation, Apr 2010, Barcelone, Spain. ⟨hal-00690490⟩
Share
Metrics
Record views
77
