New interface
Conference papers
Proteins Separation in Distributed Environment Computation
Abstract : In the present study we consider the parallel simulation on a peer-topeer demonstrator for the computation of a 3D differential equations, which model the behavior of the continuous-flow electrophoresis problem. The physical model considered is constituted by the Navier-Stokes equation coupled with a convection-diffusion equation and a Laplacian equation. By using appropriate discretization of the coupled boundary value problems, we can prove the convergence of synchronous and more generally asynchronous relaxation methods. Finally parallel experiments on the peer-to-peer demonstrator are presented and analyzed.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-00690910
Contributor : Ist Rennes Connect in order to contact the contributor
Submitted on : Tuesday, April 24, 2012 - 4:55:30 PM
Last modification on : Friday, August 5, 2022 - 2:56:21 PM
Links full text
Identifiers
Citation
Ming Chau, Thierry Garcia, Pierre Spiteri. Proteins Separation in Distributed Environment Computation. ICCSA 2011 : 11th International Conference on Computational Science and Its Applications, Jun 2011, Santander, Spain. pp.648-663, ⟨10.1007/978-3-642-21887-3_49⟩. ⟨hal-00690910⟩
Share
Metrics
Record views
67
