Column-Based matrix partitioning for parallel matrix multiplication on heterogeneous processors based on functional performance models
In this paper we present a new data partitioning algorithm to improve the performance of parallel matrix multiplication of dense square matrices on heterogeneous clusters. Existing algorithms either use single speed performance models which are too simplistic or they do not attempt to minimise the total volume of communication. The functional performance model (FPM) is more realistic then single speed models because it integrates many important features of heterogeneous processors such as the processor heterogeneity, the heterogeneity of memory structure, and the effects of paging. To load balance the computations the new algorithm uses FPMs to compute the area of the rectangle that is assigned to each processor. The total volume of communication is then minimised by choosing a shape and ordering so that the sum of the halfperimeters is minimised. Experimental results demonstrate that this new algorithm can reduce the total execution time of parallel matrix multiplication in comparison to existing algorithms.
