CrossShade: Shading Concept Sketches Using Cross-Section Curves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2012
We facilitate the creation of 3D-looking shaded production drawings from concept sketches. The key to our approach is a class of commonly used construction curves known as cross-sections, that function as an aid to both sketch creation and viewer understanding of the depicted 3D shape. In particular, intersections of these curves, or cross-hairs, convey valuable 3D information, that viewers compose into a mental model of the overall sketch. We use the artist-drawn cross-sections to automatically infer the 3D normals across the sketch, enabling 3D-like rendering. The technical contribution of our work is twofold. First, we distill artistic guidelines for drawing cross-sections and insights from perception literature to introduce an explicit mathematical formulation of the relationships between cross-section curves and the ge- ometry they aim to convey. We then use these relationships to develop an algorithm for estimating a normal field from cross-section curve networks and other curves present in concept sketches. We validate our formulation and algorithm through a user study and a ground truth normal comparison. As demonstrated by the examples throughout the paper, these contributions enable us to shade a wide range of concept sketches with a variety of rendering styles.
curvature_sketch.pdf (25.34 Mo) Télécharger le fichier
Format : Figure, Image
hal-00703202 , version 1 (01-06-2012)
hal-00703202 , version 2 (02-06-2012)
Cloud Shao, Adrien Bousseau, Alla Sheffer, Karan Singh. CrossShade: Shading Concept Sketches Using Cross-Section Curves. ACM Transactions on Graphics, 2012, Proceedings of SIGGRAPH, 31 (4), ⟨10.1145/2185520.2185541⟩. ⟨hal-00703202v2⟩
373 Consultations
879 Téléchargements
