MULTI-TARGET TRACKING BY DISCRIMINATIVE ANALYSIS ON RIEMANNIAN MANIFOLD - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper addresses the problem of multi-target tracking in crowded scenes from a single camera. We propose an algorithm for learning discriminative appearance models for different targets. These appearance models are based on covariance descriptor extracted from tracklets given by a short-term tracking algorithm. Short-term tracking relies on object descriptors tuned by a controller which copes with context variation over time. We link tracklets by using discriminative analysis on a Riemannian manifold. Our evaluation shows that by applying this discriminative analysis, we can reduce false alarms and identity switches, not only for tracking in a single camera but also for matching object appearances between non-overlapping cameras.
ICIP_final.pdf (119.38 Ko) Télécharger le fichier
hal-00703633 , version 1 (07-06-2012)
  • HAL Id : hal-00703633 , version 1
Slawomir Bak, Duc Phu Chau, Julien Badie, Etienne Corvee, François Bremond, et al.. MULTI-TARGET TRACKING BY DISCRIMINATIVE ANALYSIS ON RIEMANNIAN MANIFOLD. ICIP - International Conference on Image Processing - 2012, Sep 2012, Orlando, United States. pp.1-4. ⟨hal-00703633⟩
Collections
INRIA INRIA2
203 Consultations
308 Téléchargements
