HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Learning Cost-Efficient Control Policies with XCSF: Generalization Capabilities and Further Improvement
Didier Marin 1, 2, * Jérémie Decock 1 Lionel Rigoux 1, 2 Olivier Sigaud 1, 2
* Corresponding author
2 AMAC
ISIR - Institut des Systèmes Intelligents et de Robotique
Abstract : In this paper we present a method based on the "learning from demonstration" paradigm to get a cost-efficient control policy in a continuous state and action space. The controlled plant is a two degrees-of-freedom planar arm actuated by six muscles. We learn a parametric control policy with xcsf from a few near-optimal trajectories, and we study its capability to generalize over the whole reachable space. Furthermore, we show that an additional Cross-Entropy Policy Search method can improve the global performance of the parametric controller.
Document type :
Conference papers
Complete list of metadata
https://hal.sorbonne-universite.fr/hal-00703760
Contributor : Didier Marin Connect in order to contact the contributor
Submitted on : Monday, June 4, 2012 - 12:22:48 PM
Last modification on : Friday, January 21, 2022 - 3:35:44 AM
Identifiers
  • HAL Id : hal-00703760, version 1
Citation
Didier Marin, Jérémie Decock, Lionel Rigoux, Olivier Sigaud. Learning Cost-Efficient Control Policies with XCSF: Generalization Capabilities and Further Improvement. GECCO 2011, 2011, Dublin, Ireland. pp.1235-1242. ⟨hal-00703760⟩
Share
Metrics
Record views
124
