HOCL Programming Guide
HOCL(Higher Order Chemical Language) is a chemical programming language. Computations can be seen as chemical reactions which are controlled by a set of chemical rules. An HOCL program is composed of two parts: chemical rule definitions and solution organization. This article aims at introducing how to write chemical programs using HOCL.
