New interface
Conference papers
A Verified Library of Algorithmic Skeletons on Evenly Distributed Arrays
Abstract : To make parallel programming as widespread as parallel architectures, more structured parallel programming paradigms are necessary. One of the possible approaches are Algorithmic skeletons that are abstract parallel patterns. They can be seen as higher order functions implemented in parallel. Algorithmic skeletons offer a simple interface to the programmer without all the details of parallel implementations as they abstract the communications and the synchronisations of parallel activities. To write a parallel program, users have to combine and compose the skeletons. Orléans Skeleton Library (OSL) is an efficient meta-programmed C++ library of algorithmic skeletons that manipulate distributed arrays. A prototype implementation of OSL exists as a library written with the function parallel language Bulk Synchronous Parallel ML. In this paper we are interested in verifying the correctness of a subset of this prototype implementation. To do so, we give a functional specification (i.e. without the parallel details) of a subset of OSL and we prove the correctness of the BSML implementation with respect to this functional specification, using the Coq proof assistant. To illustrate how the user could use these skeletons, we prove the correctness of two applications implemented with them: a heat diffusion simulation and the maximum segment sum problem.
Complete list of metadata
https://hal.inria.fr/hal-00708822
Contributor : Frédéric Loulergue Connect in order to contact the contributor
Submitted on : Friday, June 15, 2012 - 7:08:39 PM
Last modification on : Saturday, June 25, 2022 - 10:11:53 AM
Identifiers
  • HAL Id : hal-00708822, version 1
Collections
Citation
Wadoud Bousdira, Frédéric Loulergue, Julien Tesson. A Verified Library of Algorithmic Skeletons on Evenly Distributed Arrays. ICA3PP, Sep 2012, Fukuoka, Japan. ⟨hal-00708822⟩
Share
Metrics
Record views
84
