A new method for learning Phrase Based Machine Translation with Multivariate Mutual Information - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Cyrine Nasri
  • Fonction : Auteur
  • PersonId : 929496
Chiraz Latiri
  • Fonction : Auteur
  • PersonId : 929497
Yahya Slimani
  • Fonction : Auteur
  • PersonId : 929498
Current statistical machine translation systems usually build an initial word-to-word alignments before learning phrase translation pairs. This operation needs so many matching between di erent single words of both considered languages. We propose a new approach for phrase-based machine translation which does not need any word alignments, it is based on inter-lingual triggers determined by Multivariate Mutual Information. This algorithm segments sentences into phrases and nds their alignments simultaneously. The main objective is to build directly valid alignments between source and target phrases. Inspite of the youth of this method, experiments showed that the results are competitive but needs some more e orts in order to overcome the one of state-of-the-art methods.
102.pdf (252.32 Ko) Télécharger le fichier
hal-00727044 , version 1 (01-09-2012)
Paternité - Pas d'utilisation commerciale - Pas de modification
  • HAL Id : hal-00727044 , version 1
Cyrine Nasri, Kamel Smaïli, Chiraz Latiri, Yahya Slimani. A new method for learning Phrase Based Machine Translation with Multivariate Mutual Information. The 8th International Conference on Natural Language Processing and Knowledge Engineering - NLP-KE'12, Sep 2012, HuangShan, China. ⟨hal-00727044⟩
504 Consultations
142 Téléchargements
