Conference papers
Gathering of Robots on Anonymous Grids without multiplicity detection
Gianlorenzo d'Angelo 1, 2 Gabriele Di Stefano 1 Ralf Klasing 3, 4 Alfredo Navarra 5
2 MASCOTTE - Algorithms, simulation, combinatorics and optimization for telecommunications
CRISAM - Inria Sophia Antipolis - Méditerranée , Laboratoire I3S - COMRED - COMmunications, Réseaux, systèmes Embarqués et Distribués
4 CEPAGE - Algorithmics for computationally intensive applications over wide scale distributed platforms
Université Sciences et Technologies - Bordeaux 1, Inria Bordeaux - Sud-Ouest, École Nationale Supérieure d'Électronique, Informatique et Radiocommunications de Bordeaux (ENSEIRB), CNRS - Centre National de la Recherche Scientifique : UMR5800
Abstract : The paper studies the gathering problem on grid networks. A team of robots placed at different nodes of a grid, have to meet at some node and remain there. Robots operate in Look-Compute-Move cycles; in one cycle, a robot perceives the current configuration in terms of occupied nodes (Look), decides whether to move towards one of its neighbors (Compute), and in the positive case makes the computed move instantaneously (Move). Cycles are performed asynchronously for each robot. The problem has been deeply studied for the case of ring networks. However, the known techniques used on rings cannot be directly extended to grids. Moreover, on rings, another assumption concerning the so-called multiplicity detection capability was required in order to accomplish the gathering task. That is, a robot is able to detect during its Look operation whether a node is empty, or occupied by one robot, or occupied by an undefined number of robots greater than one. In this paper, we provide a full characterization about gatherable configurations for grids. In particular, we show that in this case, the multiplicity detection is not required. Very interestingly, sometimes the problem appears trivial, as it is for the case of grids with both odd sides, while sometimes the involved techniques require new insights with respect to the well-studied ring case. Moreover, our results reveal the importance of a structure like the grid that allows to overcome the multiplicity detection with respect to the ring case.
Document type :
Conference papers
Complete list of metadata
Cited literature [20 references]  Display  Hide  Download
https://hal.inria.fr/hal-00728988
Contributor : Gianlorenzo d'Angelo Connect in order to contact the contributor
Submitted on : Friday, September 7, 2012 - 11:07:59 AM
Last modification on : Monday, December 20, 2021 - 4:50:10 PM
Long-term archiving on: : Saturday, December 8, 2012 - 3:40:26 AM
File
main.pdf
Identifiers
Citation
Gianlorenzo d'Angelo, Gabriele Di Stefano, Ralf Klasing, Alfredo Navarra. Gathering of Robots on Anonymous Grids without multiplicity detection. 19th International Colloquium on Structural Information and Communication Complexity (SIROCCO 2012), Jun 2012, Reykjavík, Iceland. pp.327-338, ⟨10.1007/978-3-642-31104-8_28⟩. ⟨hal-00728988⟩
Share
Metrics
Record views
263
Files downloads
301
