From a Store-Collect Object and Ω to Efficient Asynchronous Consensus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents an efficient algorithm that build a consensus object. This algorithm is based on an Ω failure detector (to obtain consensus liveness) and a store-collect object (to maintain its safety). A store-collect object provides the processes with two operations, a store operation which allows the invoking process to deposit a new value while discarding the previous value it has deposited and a collect operation that returns to the invoking process a set of pairs (i, val) where val is the last value deposited by the process pi . A store-collect object has no sequential specification. While store-collect objects have been used as base objects to design wait-free constructions of more sophisticated objects (such as snapshot or renaming objects), as far as we know, they have not been explicitly used to built consensus objects. The proposed store-collect-based algorithm, which is round-based, has several noteworthy features. First it uses a single store-collect object (and not an object per round). Second, during a round, a process invokes at most once the store operation and the value val it deposits is a simple pair r, v where r is a round number and v a proposed value. Third, a process is directed to skip rounds according to its view of the current global state (thereby saving useless computation rounds). Finally, the algorithm benefits from the adaptive wait-free implementations that have been proposed for store-collect objects, namely, the number of shared memory accesses involved in a collect operation is O(k) where k is the number of processes that have invoked the store operation. This makes the proposed algorithm particularly efficient and interesting for multiprocess programs made up of asynchronous crash-prone processes that run on top of multicore architectures.
Fichier non déposé
hal-00733080 , version 1 (17-09-2012)
  • HAL Id : hal-00733080 , version 1
Michel Raynal, Julien Stainer. From a Store-Collect Object and Ω to Efficient Asynchronous Consensus. Euro-Par - Parallel Processing - 18th International Conference - 2012, 2012, Rhodes Island, Greece. pp.427-438. ⟨hal-00733080⟩
134 Consultations
0 Téléchargements
