Checkpointing strategies for parallel jobs. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This work provides an analysis of checkpointing strategies for minimizing expected job execution times in an environ- ment that is subject to processor failures. In the case of both sequential and parallel jobs, we give the optimal solu- tion for exponentially distributed failure inter-arrival times, which, to the best of our knowledge, is the first rigorous proof that periodic checkpointing is optimal. For non-ex- ponentially distributed failures, we develop a dynamic pro- gramming algorithm to maximize the amount of work com- pleted before the next failure, which provides a good heuris- tic for minimizing the expected execution time. Our work considers various models of job parallelism and of parallel checkpointing overhead. We first perform extensive simula- tion experiments assuming that failures follow Exponential or Weibull distributions, the latter being more representa- tive of real-world systems. The obtained results not only corroborate our theoretical findings, but also show that our dynamic programming algorithm significantly outperforms previously proposed solutions in the case of Weibull fail- ures. We then discuss results from simulation experiments that use failure logs from production clusters. These results confirm that our dynamic programming algorithm signifi- cantly outperforms existing solutions for real-world clusters.
paper.pdf (429.74 Ko) Télécharger le fichier
hal-00738504 , version 1 (04-10-2012)
  • HAL Id : hal-00738504 , version 1
Marin Bougeret, Henri Casanova, Mikael Rabie, Yves Robert, Frédéric Vivien. Checkpointing strategies for parallel jobs.. SuperComputing (SC) - International Conference for High Performance Computing, Networking, Storage and Analysis, 2011, 2011, United States. pp.1-11. ⟨hal-00738504⟩
236 Consultations
346 Téléchargements
