New interface
Patents
Method for estimating the movement of a traveling observation instrument flying over a celestial body
Régis Perrier 1, * Mathias Ortner 2 Élise Arnaud 3, * Peter Sturm 3, *
* Corresponding author
1 PERCEPTION - Interpretation and Modelling of Images and Videos
Inria Grenoble - Rhône-Alpes, LJK - Laboratoire Jean Kuntzmann, Grenoble INP - Institut polytechnique de Grenoble - Grenoble Institute of Technology
3 STEEP - Sustainability transition, environment, economy and local policy
Abstract : The invention relates to a method for estimating the movement of an observation instrument (10) on-board a vehicle flying over a celestial body, the observation instrument (10) comprising at least two bars (b1, b2) the lines of sight of which are different, each bar acquiring consecutive line images forming a composite image, portions of the composite images representing substantially a single scene of the celestial body. The estimated movement is determined by means of optimizing an image resemblance function which associates a resemblance between matching pixel values of at least one pair of composite images with a given movement hypothesis, and, for each movement hypothesis considered during optimization of the image resemblance function, the method comprises the steps (200) of determining at least one space-time transformation for the at least one pair of composite images on the basis of the movement hypothesis in question and a geometric model of the observation instrument (10), and (201) matching the pixels of at least one pair of composite images by means of the at least one space-time transformation.
Complete list of metadata
https://hal.inria.fr/hal-00746464
Contributor : Peter Sturm Connect in order to contact the contributor
Submitted on : Monday, October 29, 2012 - 10:13:58 AM
Last modification on : Wednesday, April 27, 2022 - 11:54:02 PM
Identifiers
  • HAL Id : hal-00746464, version 1
Citation
Régis Perrier, Mathias Ortner, Élise Arnaud, Peter Sturm. Method for estimating the movement of a traveling observation instrument flying over a celestial body. France, Patent n° : WO/2011/061123. 2010. ⟨hal-00746464⟩
Share
Metrics
Record views
198
