New interface
Journal articles
ecoPrimers: inference of new DNA barcode markers from whole genome sequence analysis.
Tiayyba Riaz 1 Wasim Shehzad 1 Alain Viari 2 François Pompanon 1 Pierre Taberlet 1 Eric Coissac 1
2 BAMBOO - An algorithmic view on genomes, cells, and environments
Inria Grenoble - Rhône-Alpes, LBBE - Laboratoire de Biométrie et Biologie Evolutive - UMR 5558
Abstract : Using non-conventional markers, DNA metabarcoding allows biodiversity assessment from complex substrates. In this article, we present ecoPrimers, a software for identifying new barcode markers and their associated PCR primers. ecoPrimers scans whole genomes to find such markers without a priori knowledge. ecoPrimers optimizes two quality indices measuring taxonomical range and discrimination to select the most efficient markers from a set of reference sequences, according to specific experimental constraints such as marker length or specifically targeted taxa. The key step of the algorithm is the identification of conserved regions among reference sequences for anchoring primers. We propose an efficient algorithm based on data mining, that allows the analysis of huge sets of sequences. We evaluate the efficiency of ecoPrimers by running it on three different sequence sets: mitochondrial, chloroplast and bacterial genomes. Identified barcode markers correspond either to barcode regions already in use for plants or animals, or to new potential barcodes. Results from empirical experiments carried out on a promising new barcode for analyzing vertebrate diversity fully agree with expectations based on bioinformatics analysis. These tests demonstrate the efficiency of ecoPrimers for inferring new barcodes fitting with diverse experimental contexts. ecoPrimers is available as an open source project at: http://www.grenoble.prabi.fr/trac/ecoPrimers.
Complete list of metadata
https://hal.inria.fr/hal-00746852
Contributor : Marie-France Sagot Connect in order to contact the contributor
Submitted on : Monday, October 29, 2012 - 6:27:58 PM
Last modification on : Tuesday, October 25, 2022 - 4:24:40 PM
Links full text
Identifiers
Citation
Tiayyba Riaz, Wasim Shehzad, Alain Viari, François Pompanon, Pierre Taberlet, et al.. ecoPrimers: inference of new DNA barcode markers from whole genome sequence analysis.. Nucleic Acids Research, 2011, 39 (21), pp.e145. ⟨10.1093/nar/gkr732⟩. ⟨hal-00746852⟩
Share
Metrics
Record views
391
