On the alpha-Reconstructibility of Workflow Nets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Eric Badouel
  • Fonction : Auteur
  • PersonId : 833447
The process mining algorithm alpha was introduced by van der Aalst et al for the discovery of workflow nets from event logs. This algorithm was presented in the context of structured workflow nets even though it was recognized that more wokflow nets should be reconstructible. In this paper we assess alpha algorithm and provide a more precise description of the class of workflow nets reconstructible by alpha.
hal-00748230 , version 1 (05-11-2012)
Eric Badouel. On the alpha-Reconstructibility of Workflow Nets. Application and Theory of Petri Nets - 33rd International Conference, PETRI NETS 2012, Hamburg, Germany, June 25-29, 2012. Proceedings, Jun 2012, Hamburg, Germany. pp.128-147, ⟨10.1007/978-3-642-31131-4⟩. ⟨hal-00748230⟩
160 Consultations
0 Téléchargements
