On Evolving Partitioned Web Service Orchestrations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Aymen Baouab
Olivier Perrin
  • Fonction : Auteur
  • PersonId : 755677
  • IdRef : 171122291
Claude Godart
  • Fonction : Auteur
  • PersonId : 830462
  • IdRef : 031091733
Many researches argue that centralized Web Service (WS) orchestrations stop short in dealing with key requirements such as scalability, privacy and reliability. Consequently, fragmentation and decentralization have been proposed to overcome these limitations. In detail, the centralized orchestration is fragmented into behaviorally equivalent distributed partitions such that their combined execution recreates the function of the original orchestration. However, the evolving nature of business processes as well as the necessity to adapt to market changes created the need for an efficient change support. Since the decentralization leads to the distribution of the activities, the control and data flows, it becomes difficult to specify the changes directly on the derived partitions. Therefore, it is more judicious to specify the changes on the centralized orchestration model and propagate the changes to the derived partitions. In this paper, we propose a comprehensive change framework for partitioned WS orchestration scenarios and demonstrate how to specify and propagate the changes from the centralized model to its resulting decentralized partitions. The main advantage of such an approach is that only partitions that are related to the specified changes are affected. There is no need to re-compute the whole orchestration and re-deploy all the distributed partitions.
SOCA1064-Fdhila.pdf (445.04 Ko) Télécharger le fichier
hal-00748691 , version 1 (26-11-2012)
  • HAL Id : hal-00748691 , version 1
Fdhila Walid, Rinderle-Ma Stefanie, Aymen Baouab, Olivier Perrin, Claude Godart. On Evolving Partitioned Web Service Orchestrations. IEEE International Conference on Service-Oriented Computing and Applications, Dec 2012, Taipei, Taiwan. ⟨hal-00748691⟩
136 Consultations
204 Téléchargements
