Industrial Application of a Second Order Sliding Mode Observer for Speed and Flux Estimation in Sensorless Induction Motor - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2012
In this chapter, a second order sliding mode observer for the induction motor (IM) without mechanical sensor is presented for the open problem of sensorless IM drives at very low frequency. This observer converges in finite time and is robust to the variation of parameters. To illustrate the proposed observer, firstly a very simple case is presented in order to exemplified the tuning parameters. Then, to highlight the technological interest of the proposed method and also show the difficulties due to real time computation constraints when a basic microprocessors are used, an industrial application is proposed.
Automatique
73410_Ghanes_first.pdf (1.11 Mo) Télécharger le fichier
hal-00749735 , version 1 (08-11-2012)
Sebastien Solvar, Malek Ghanes, Leonardo Amet, Jean-Pierre Barbot, Gaëtan Santomenna. Industrial Application of a Second Order Sliding Mode Observer for Speed and Flux Estimation in Sensorless Induction Motor. INTECH. Induction Motors - Modelling and Control, INTECH, 2012, ISBN 978-953-51-0843-6. ⟨10.5772/52910⟩. ⟨hal-00749735⟩
480 Consultations
356 Téléchargements
